Configure RIPng parameters on an interface so you can control RIPng behavior on the interface.
  • Configure a routing interface (either a brouter port or a virtual routing interface).
  • Assign an IP address to the interface.
  • Enable RIPng globally and on the interface.
RIPng does not operate on an interface until you enable it globally and on the interface.
  1. In the Device Physical View, select a port.
  2. In the navigation pane, expand Configuration >EditPort.
  3. Select IPv6.
  4. Select the RIPng tab.
  5. In RipAdminStatus, select enable.
  6. Configure other parameters as required.
  7. Select Apply.
RIPng Field Descriptions
Use the data in the following table to use the RIPng tab.
Name Description
RipAdminStatus
Enable or disable RIPng on an interface.
DefaultInfoState
Enable or disable default information at the interface level. The default is disable.
Cost
Specifies the RIPng metric cost. The default is 1.
Poison
Enable or disable poison reverse on an RIPng interface. The default is disable.
RipOperStatus
Shows the RIPng operational state on an interface.
